what ever happened to the Blown Prairie?
Yetti,
I have been on a Munchkin Run this weekend will post a strip on the run later. As for the Super Charged engine it is on the floor in the corner of the toy shop in pieces as I spun a bearing on my last run this spring. Further inspection of the motor I found the con rods were twisted by 15* mostly from the extra boost I do believe. I may opt for EFI this next year with 2 or 3 stage Nos system plus a programable ignition I think it will produce more steady results.
Friesen,
Toys are still in their proper place LOL I had stainless strap that mounts over the heads of the motor in case the heads want to leave the engine while I am riding with blower attached. I have a motor I picked up from the junkers this is the motor I have been playing with this summer but I think the trany is toast I can't keep it in gear anymore it rachets real bad in both ranges now. I will have to pull this engine to get into the trany to find its problem.
PrWr,
Keep up the good work when will you have the big bore kit in your machine?
Friesen,
PrWr,
Sw00p
Sep 24, 2015 02:50 PM
