Brakes locked up!
Old Aug 31, 2003 | 10:42 PM
sledgehammer650's Avatar
Default Brakes locked up!
Ive just rebuilt the brake on my buds polaris cause they keep locking up. i honeed out the calipers and lubed the new o-rings and it stills wants to lock up HELP!! please.
Old Aug 31, 2003 | 11:35 PM
Is this the only polaris thats doing this? The guy that owns it is a great guy and i want to help him out with out him getting chargeed to much at a shop. I think its might be in the caliper mechanism that moves the pads itself has anyone ran into this should i take them apart? The little rubber piece looks like it would be hard to get back in.
Old Sep 1, 2003 | 12:28 AM
Farmr123's Avatar
Never had that problem before....
Old Sep 1, 2003 | 10:20 AM
Thanks Farmr 123 by the way its one just like yours. I guess ill have to atleast call the dealer i know what there going to say bring it in. Thanks guys!!
Old Sep 1, 2003 | 10:41 AM
BlueBlaster's Avatar
Are all 3 brake calipers locked up or is it just one of them. If they are all locked up it sounds like there is a problem with the master cylinder. It is not letting pressure off of the calipers piston. If only one is locked up it is probably a problem with one of the brake hoses. To test to see if that is the problem open the bleeder screw on the caliper that is locked up. If fluid comes out and the brake is free, you need to replace the brake hose for the caliper.
Old Sep 1, 2003 | 10:48 AM
Farmr123's Avatar
Good point. Also, if you loosen the bleeder, and the brake STILL drags, the caliper is stuck. Had that problem with my old pickup (stuck caliper). Never could get it to work right, so I broke down & got a rebuilt one.
Farmr
Old Sep 1, 2003 | 10:32 PM
Just the two front are sticking. Not at the same time thow left and then right.
Old Sep 2, 2003 | 08:23 AM
tblazerdad's Avatar
Sounds to me like dirt in the fluid and/or line. Did you flush the lines. There is also a very small hole in the bottom of the master cylinder bowl that the fluid returns through. Make sure that it is not blocked. You may have to disassemble the master cylinder and blow air through the hole. If the brakes let go when you open the bleeder then your return flow is restricted. I've seen this happen on street bikes before.
Old Sep 3, 2003 | 05:06 PM
Thanks guy Iam going to call my friend and tell him all that you guys have said. I did tell him if only the left front was sticking after i rebuilt the calibers that he should loosen the allen set screw a little. It looks let there should be a setting there but i have no manual.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
