rear brake problem 250r
Old Sep 3, 2003 | 01:12 AM
MEAN250RFEIN's Avatar
Default rear brake problem 250r
I have a 1985 250r with a failed rear brake. It is full of fluid and I have tried bleeding it. When pumping the pedal with the bleeder open it has no pressure at all and spits out a little fluid at a time (very little).
With the bleeder valve closed when I pump on the pedal (with fluid), there is no pressure at all and I see no signs of leakage while pumping. Please help with suggestions.
Old Sep 3, 2003 | 01:37 PM
Mike330R's Avatar
Sounds like air in the lines. Get a brake bleeding kit. It's a pump that you attach to the bleeder. it pulls fluid through the system. Much easier than pumping the brake, closing the bleeder, and repeating.
Old Sep 3, 2003 | 10:05 PM
85ATC350X's Avatar
either youre not bleeding them right or the master cylinder has failed.
Old Sep 4, 2003 | 09:02 PM
dragracer789's Avatar
the thing (i dont know what it is exactly called, mabey pump?) that pumps the fluid into the brake lines might need new seals. I did on my 200x.
Old Sep 12, 2003 | 05:17 PM
newguy185's Avatar
You should put new seals in your master cylinder.[img]i/expressions/face-icon-small-smile.gif[/img]
AK47KID
Jul 23, 2015 09:21 PM
rcappie4
Jun 21, 2015 07:40 PM
scaldwellk
Jun 19, 2015 05:08 PM
UPLou
Jun 7, 2015 09:42 AM
CountryMiles
Oct 25, 2000 01:03 AM
