what about a sp700 for $4500...........Help!!!!!!
Old Sep 4, 2003 | 07:40 PM
curlytop's Avatar
Default what about a sp700 for $4500...........Help!!!!!!
My dad found a 2002 sp700 at a bank that was a repo and said that they wanted $4500 for it.
Is this a good deal and what are some things that I need to look for. Also how can I be sure the 4x4 system works before I buy it, if there is any.
Old Sep 4, 2003 | 10:06 PM
curlytop's Avatar
come one guys someone has to know if this is a good deal or not. Also what are some things I should be looking for.
Old Sep 4, 2003 | 11:10 PM
upnort's Avatar
2002 had a water pump prob not sure how to tell if it has been updated. As for the 4x4 if could get all 4 wheels off ground could check. Or get in some loose sand and give er a bit. OR hook up a rope to your toyota and pull that. ;-) Dollar wise is a decent deal.
Old Sep 5, 2003 | 09:45 AM
Brushcrusher's Avatar
Sounds like a great deal,I'd grab it youll love the machine. How many miles/Hrs.? what condition?
Old Sep 6, 2003 | 02:06 AM
curlytop's Avatar
well guys, i did it. I bought the 700 for $4000 and in fair condition with 150 hrs. Also has a 2000lbs warn winch with it. The only problems that i have found are speedometer dosn't work, and has a hole in the clear radiator hose that doesn't leak unless you take off the top to the resovor. I also got it stuck the first day I got it. Water was over my left headlight and wouldn't go anywhere. It dug ruts knee-waist deep, but I still love it. How do you check the hub fluid. Also where is the dipstick for the oil.
Old Sep 6, 2003 | 02:20 AM
Can't find the dipsitck ?? are you kiddin ? BS
Old Sep 6, 2003 | 02:22 AM
curlytop's Avatar
to tell you the truth I hadn't even looked yet.
Old Sep 6, 2003 | 02:36 AM
curlytop's Avatar
I just didn't know if it was under the side panel.
Old Sep 6, 2003 | 02:44 AM
C'mon.....left side DA
Old Sep 6, 2003 | 02:47 AM
curlytop's Avatar
thanks, How do you check the hub fluid.
