warn 424 easy to install?
Old Sep 4, 2003 | 09:30 PM
Eceriderjbomb's Avatar
Default warn 424 easy to install?
i got a wolvy im just wondering if its easy to install it we were gioing to send it the shop but if we can do it ourselfs it would be better
happy birthday to me is right
Old Sep 4, 2003 | 09:47 PM
WolverineMan15666's Avatar
Its very easy. The hardest part is breaking loose the bolts that hold the front differential in place. They are really tight. You will have to back out the bolts on the lower right A-arm to get the bolts of the differential out. ( Its hard to explain but you will see) The drive shaft just about falls out. You put the spring, clips, and boots (My '98 doesn't have boots ) from the old drive shaft on the 424. There's a little bit more to do but its really easy to install. I did it in about an hour, but I had my old drive shaft ( keep your old one for the spring and clips )out before the 424 even came to the house. Just follow the instructions and you will be OK. Wait 'till you take your first ride in 2WD. Your Wolverine will feel like a whole different quad. MAKE SURE YOU LEAN IN THE TURNS, MORE THAN YOU DID WHEN IT WAS 4WD. I almost rolled mine in the yard my first ride. It takes some getting use to. Good Luck!
Jeff Roper
Feb 1, 2022 11:48 AM
exmotocrosser
Sep 13, 2019 06:12 AM
mrtidy
Feb 3, 2016 05:00 PM
2many2ride
Sep 27, 2015 04:35 AM
exmotocrosser
Sep 26, 2015 08:18 AM
