03 TRAILBOSS Trans Vibration
Old Sep 6, 2003 | 02:13 PM
LogLeaper's Avatar
Default 03 TRAILBOSS Trans Vibration
I just pic up a 03 trailboss and at HIGH idle it makes a awful VIBRATION/grinding sound while in neutral ,,,,
under load theres no sound at all , in F or R theres no sound either .....
I took it back to the dealer ( 1 hour old ) and the mechanic said all those bosses do that ....
factory polaris knows about this VIBRATION at high idle ...... we tried another one from the floor and it to did it but much less than mine .....
he said he's heard worse too ,,,, hmmm .
has anyone heard of this inhearent trans vibration problem before ......
dont get me wrong in gear it runs fine !!!!!!
well the dealer offer me a new one ( problem could still be there from the fatory though ) or "balance" the old one and see if they can take care of it ......
it could be something simple I just dont want a rebuild the first hour of idling , though a good look inside could reveal the problem and a GOOD balance always beats the factory.
do all you other TB owners have this same simptom ..... I'd hate to go thru 2-3 of these to find a good one.
Old Sep 6, 2003 | 06:38 PM
Lukester's Avatar
I have an 03 Trail Boss and it does not have the vibration you describe.
Old Sep 6, 2003 | 08:32 PM
markbanger's Avatar
mine dosen't viberate.
Old Sep 8, 2003 | 12:48 AM
BossMann's Avatar
Haven't had that on mine, but the trans case has devoloped a leak at 10 hrs .Also you need to check the 2 brass nipples that come out of the fuel tank to see if they are leaking fuel.I saw this in another forum , I checked mine & it also was leaking.At dealership now getting both leaks & the brakes fixed.[img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Jan 28, 2004 | 01:33 PM
Jaycee1964's Avatar
my 2003 boss is fine.
Old Jan 28, 2004 | 04:09 PM
2004TrailBoss's Avatar
My 2004 does not vibrate like that
Old Jan 28, 2004 | 04:19 PM
LogLeaper's Avatar
thanks all, Found out the problem, it was a ( harmonics of the gears while in neutral )
At just the right RPM’s in neutral I get some ( harmonic vibration ) that even extends to the rear shock springs.
I did get another atv and it was much less than the others we tried…….
Though at the right RPM it still send the plastic ( hood piece ) a shack’n
Old Jan 28, 2004 | 04:41 PM
Jaycee1964's Avatar
My hood does vibrate but it is an off road ATV. I put doublesided tape to stop the shake. belive me after a few trail rides there will be more Vibs!!! [img]i/expressions/face-icon-small-wink.gif[/img]
68_327_c20
Nov 25, 2023 12:26 PM
Myronh
Sep 8, 2015 11:27 AM
binky79
Jul 30, 2015 06:37 PM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
willster
Mar 12, 2000 11:17 PM
