99 Sportsman Tire Selection???
Old Sep 8, 2003 | 10:06 PM
MuddinRacer's Avatar
Default 99 Sportsman Tire Selection???
I am looking in to getting some new tires for my four wheeler. Should I go with a 26" tire or just stay with the 25" tire. I am looking at the mudlites, but they are too big for the front if I go with a 26" tire. What do you all think??? Thanks for you suggestions!!!
Old Sep 9, 2003 | 07:31 AM
upnort's Avatar
I put the 27" C-series on my sp500 and it was a pain in the a$$. Had to use 1" spacers, then they rubbed on the fenders, so tightened up springs and used spacers.. Think I would have maybe gone with 9" wide on front rather than 10, but since I did not try do not know how they would do. Back was just fine no prob.
Old Sep 9, 2003 | 06:47 PM
What would you or anybody else recommend for a 26" tire. I wanted the lightest mud tire available in 26x9x12 in the front and probably 26x10x12 or 26x12x12 in the back. Does anybody got in suggestions??? Thanks!!!
Old Sep 10, 2003 | 07:29 AM
upnort's Avatar
The 589 m/s are supposed to be a bit on the lighter side. Had 26X10X12 rears on my explorer that got me through a mud hole that I could not do stock. But with all the mud lite hype went with those instead when bought full set.
Old Sep 10, 2003 | 10:05 AM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
THe 25" tire will do fine. THe 589 is more agressive but rides rougher. The MudLitye is a good choice.
Old Sep 10, 2003 | 07:22 PM
Thank you both, but how much more ground clearance will I have over the 25" tire. Just one inch, but I would think it would be a little more??? This may be a dumb question, and I am sorry!!!
Old Sep 10, 2003 | 09:23 PM
upnort's Avatar
In theory you will only get 1/2 " more ground clearance since 26 is the diameter or height, 1/2" more under (hub to bottom of tire) or ground, 1/2" more above (hub to top of tire). Although there is some variance in different tire brands. I really do not feel much differance in the ride of the mudlite vs 589 M/S, they are both bumpier at low speeds mostly on hard pack. BTW there is no such thing as a dumb question.
Old Sep 10, 2003 | 10:32 PM
hotdog's Avatar
I was wondering would you see a power loss with the bigger tires ????
Old Sep 10, 2003 | 10:58 PM
upnort's Avatar
Yes you will definately, but is a trade off. Lose bit of top end but better traction. Not all that noticable though. Lost about 7 mph going from stock 25 to 27 mudlites on my 500ho.
Old Sep 11, 2003 | 12:44 AM
Traildog's Avatar
I run 26"x10x12s on the front and 26"x12x12 on the rear mounted on ITP C series rims. The rear are no problem but the front tires rub the fenders, annoying! I installed P HD springs up front along with a Wayne Gretzky lift kit, well actually one cut into tow and installed half in each side. This raised the front approx.. 1 1/2" at the rack and did improve the rubbing problem but did not eliminate it entirely.
Another problem was the tire rubbed the tie-rod-end and that was fixed using 2 washers on each stud. I am happy with this setup but it would be nice to eliminate the rubbing all together.
