yzf450 kicker
Old Sep 11, 2003 | 10:28 AM
airtimehocutt's Avatar
Default yzf450 kicker
has anyone actually riden a yzf450 with the electric started and battery removed? if so, how hard was it to kick (forward or reverse) and does it start easily? and a true weight wih the electric start and without. not yamaha's spec either
Old Sep 11, 2003 | 10:29 AM
Yamaha4eva's Avatar
i dunno but a raptor would be a b!tch to kick start, that thing requires so much compression...
Old Sep 11, 2003 | 10:30 AM
warrior007's Avatar
Check out member "selector" he has his YFZ down quite a few pounds and uses the kicker off the bike.
Old Sep 11, 2003 | 10:36 AM
selector's Avatar
Riden and own.
Easy to kick.
13.5lbs less w/ battery, starter, starter gear, fan, wires, etc. removed.
I will not/cannot go back to electric start - I even cut the battery housing out as seen in this profile...
selector
Old Sep 11, 2003 | 10:40 AM
you removed the electric cooling fan also? well, i guess it won't work without a battery. is yours a factory delete electric start or did you do it your self?
selector
Aug 23, 2003 06:58 PM
250R4LIFE
Aug 13, 2003 07:21 AM
quadracerkid
Aug 3, 2003 07:54 PM
sks3266
ATC 3-Wheelers
Aug 1, 2002 12:37 PM
