Sportsman 600 vs. Grizzly 660 comparison
Old Sep 12, 2003 | 11:54 AM
waderman's Avatar
Default Sportsman 600 vs. Grizzly 660 comparison
Just sold my 02 Grizzly 660 and bought 04 1/2 SP600. After first weekend on SP here are my opinions:
1. Engine - Grizzly wins by slight margin. It felt a little stronger and sounded better with its louder
grumbling noise. Griz topped out in low 60's, haven't tested SP's top end yet. Throttle response seems
similar on both.
2. Suspension & handling - Toss-up. The Griz may have rode slightly plusher but the SP is real close and
its steering is noticably lighter. Other suspension and handling characteristics seem similar. The SP
suspension components (and also driveline) make alot more noise than the Griz. I don't like that. The
SP is roughly 140 lbs. heavier than the Griz but to be honest I don't feel it in its handling.
3. Ergonomics - Toss-up. I seem to sit slightly higher on the SP but I like the placement of the instruments
better than the Griz. Trans shifters are on oposite sides on these machines. I have no preference
regarding that. I like the single lever brake on the SP.
4. Transmission - SP600 wins. The trans on both machines are similar in most respects but the shifter
stalk on the SP is clearly superior. It's much easier to use (the forward-low to reverse pattern on SP is
awesome). The Griz's shifter is notchy, hard to engage, forward to reverse is a pain in ***, and the
zig-zag pattern sucks.
5. 4 wheel drive system - SP600 wins. For my kind of riding, this "leave it on and forget it" system is
superior. I got real tired of constantly pushing buttons, sliding levers and pushing more buttons on the
Griz. It's too complicated and the lag between limited slip and full lock 4wd is a problem. Backing up in
full lock 4wd is a joke on the Griz (although new models have over-ride button). The SP is either 2wd or
full lock 4wd (no limited slip 4wd). This suits me fine and its automatic application lets me concentrate
on the trail.
6. Brakes - SP600 wins. For some reason the brakes on my Griz (even after replacing) were always
mushy. The SP's seem OK and I prefer the one lever.
7. Misc. - Toss-up. Racks on SP600 win by slight margin. SP's are very easy to remove for cleaning and
won't chip like the Griz's but they are harder to hook bungee cords to because of the thickness.
Floorboards are better on SP. Griz has more storage space under seat. Access to engine/fluids is
similar. The Griz in my opinion is better looking with its mean front end. The red suspention components
on the SP are cool looking, however. The tires seem similar (apparently they cheapened the tires on
the 04 1/2 SP's).
CONCLUTION - Both machines are similar in many ways but based on the above the SP wins primarily because of its 4wd system and to a lesser extent it's trans shifter. There is one crutial thing not mentioned above. THE GRIZ IS NO GOOD IN WATER/MUD!!!!! Steam from the engine gets into the carbs and it sputters and cuts-out. This was a huge problem with mine and many other Griz owners. Yamaha has supposedly fixed the problem with vented side panels but I still hear about it. There are other issues with the older Griz 660's that they claim to have straightened out. This remains to be seen. I know there have been problems with early SP twins as well but the Griz's inability to run in water/mud is huge.
One problem with my SP I need advise on: the battery light on the dash flashes on and off all the time. The battery has a full charge and the dealer connected something in the front end that the factory forgot about but the light still flashes. I disconected the battery and reconected it but it still does it. The machine runs fine. Any suggestions?
Old Sep 12, 2003 | 03:24 PM
savage21's Avatar
Good Info.
Old Sep 12, 2003 | 06:08 PM
polaris5610's Avatar
Hey i have a ?, how are the new tires? I mean do they mud good and how do they ride? About the battery, if your head lights were on it will come on from time to time. I have no clue why, it seems to do it when the atv is sitting there. I dont know if these is why yours does it.
Old Sep 12, 2003 | 06:43 PM
fredbear92's Avatar
Thank you for this informative and honest evaluation of these two quads.Ive been polaris faithful all my life but was considering jumping to the yamaha ship .Your honest and unbiased evaluation has convinced me that polaris is the better ride.Thanks again.
Old Sep 12, 2003 | 07:37 PM
Polaridoo's Avatar
My '02 700 sometimes does the same thing with the battery indicator. It seems to only do it once in a while when the lights are on, the fan is on, and the engine is at an idle. My only guess is that the battery indicator turns on too early - before there is even a problem. To be honest, I don't know why and there seems to be no reason for it. I mean the battery starts the machine up easily and it checks out fine voltage wise.
Old Sep 15, 2003 | 10:29 AM
waderman's Avatar
Aaron,
The tires seem OK. I can only compare them to the stock tires on my Grizzly. They don't ride quite as smooth but are more aggressive. Their mud performance should be better than the ones on the Griz. I heard they switched from the outlaws to these to save weight. I have no experiance with the outlaws so I can't say. I think they probably did it as a cost cutting measure, however.
Old Sep 15, 2003 | 07:35 PM
Ok, thanks for the information on the new tires. I have a 03 700 and it has the Rawhide. I had heard mixed reports on the tires Polaris is using now. At any rate, keep us up to date on your Sportsman. I am really intrested in the 04 1/2 SP's.
Old Sep 21, 2003 | 12:35 AM
Danzig's Avatar
Hi Waderman,
How do you like the Carlisle tires??? Would your Sp600 beat out the Grizz 660 in a 600ft drag race?? Let me know how much you like (or dislike) your SP 600. My dealer has great deals on a 2004 Sp600 and I am looking for feedback from riders before I buy. Thanks.
greg74
Sep 10, 2019 03:03 PM
DFWSRT8
Aug 20, 2015 09:24 AM
Stirling
Aug 11, 2015 07:23 AM
Jul 28, 2015 12:12 PM
RticKwad
Jul 21, 2015 03:00 PM
