sprocket help
Old Sep 12, 2003 | 02:56 PM
Hondanutcase's Avatar
Default sprocket help
Would it be better to change the front sprocket or rear sprocket for more low end on my 400ex
Old Sep 13, 2003 | 08:31 PM
Slacker1bob's Avatar
It is easier and cheaper to change the front. Taking one tooth off the front is equal to adding 4 on the rear(roughly). You can fine tune more with the rear.
Old Sep 13, 2003 | 11:58 PM
dsheola's Avatar
If you go down to a 14 tooth renthal front sproket you will notice if you ride motorcross that you can keep it in 3rd even in the corners with little clutch work.
check out the review here 14 tooth sproket review exriders.com
Old Sep 14, 2003 | 02:52 AM
If he put on a 14 tooth, that would be going up, not down. Also, that would add more top end and less low end torque. But if that is the goal, then thats the way to go.
Old Sep 17, 2003 | 01:02 PM
Thanks for all your advice. I ordered my 14 tooth sprocket and will be installing as soon as I get it.
Old Sep 17, 2003 | 02:14 PM
Originally you were going for lowend, but you ordered a high end Sprocket. ???????????????
Old Sep 17, 2003 | 02:23 PM
I have been informed by numerous people and my local Honda dealer that a smaller sprocket in the front has the opposite affect of a smaller sprocket in the rear. A 14 tooth sprocket in the front is equivalent to adding three teeth in the rear.
Old Sep 17, 2003 | 04:43 PM
What size sprocket did you start with. I thought they came with 13 tooth stock sprockets. IF you started with a 15 tooth, then I guess your right
Old Sep 17, 2003 | 07:07 PM
The stock sprocket is a 15 tooth. Thanks you had me worried there for a second.
Old Sep 17, 2003 | 07:46 PM
SCOOT400EX's Avatar
hey slacker the stock teeth are 15 front and 38 in the rear. How well does your lt250 do on trails?
I like the lts 250 & 500 very fun.
