87 mojave feels slower then my 87 guadsport 230. WHY??????
Old Sep 19, 2003 | 06:47 PM
jiffy's Avatar
Default 87 mojave feels slower then my 87 guadsport 230. WHY??????
i just got my mojave back from getting the output shaft and gears replaced. i took it out for a ride and it feels alot slower then my quadsport 230. why is that? Isnt it suppoesed to be faster?
Both quads are 100% stock. well, both have 20 inch rear tires.
jeff
Old Sep 19, 2003 | 11:23 PM
mojaveman342's Avatar
????? i just got my mojave too but it does seem slow at all. ??????
Old Sep 20, 2003 | 12:22 AM
jiffy's Avatar
its an 87 mojave. and the quadsport is also an 87. which one is supposed to be faster? i would think the one with the bigger engine.
Old Sep 20, 2003 | 01:14 AM
2004ds650's Avatar
maybe it needs a rebuild. and displacement dosent always mean everything but yest the high tech 250 should beat the low tech 230
Old Sep 22, 2003 | 01:20 AM
toyaddict's Avatar
Check the rear brake also, I've seen a ton of mojaves where the rear brake was dragging, it doesn't have to drag much to really make a difference.
Old Sep 30, 2003 | 02:50 PM
mojavekid13's Avatar
Man Iam getting my mojave outputshaft and gears done right now!
What all did you replace and how much$$$$$$$$$$
Old Oct 2, 2003 | 12:11 AM
jiffy's Avatar
um. I am not really sure. my buddy is doing it. I know i need an output shaft. MIne was completely sheared in half. also two kickstart gears where broken apart. and also i think i ned shift forks.
the output shaft was 90 dollars and the two gears and shift forks are 35 each. i also am replaceing the clutch, rear shock, front and rear tires, new exhaust, jet kit, and whatever else is wrong with it. My buddy gave it to me. When he bought his 87 the guy gave him a parts one and i decided to fix it up and he gave it to me. i think i am 500 dollars into it now.
jeff
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
QuadRiders
Oct 22, 2015 04:13 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
bvolks
Sep 13, 2015 12:57 PM
