What is the best way to set the floats?(raptor)
Old Sep 21, 2003 | 03:38 AM
Slowwarrior's Avatar
Default What is the best way to set the floats?(raptor)
What is the best way to set the floats on a raptor? I have read in the manual that you want to turn them upside and then measure 13mm (.51inches). With the float tang resting on the needle valve but not depressing it which to try and feel or see is a major pain. So when doing it, it seems really hard to be that precise. So I was wondering if anyone else had a good way to do it?
Old Sep 21, 2003 | 04:19 AM
Ward660R's Avatar
You are correct, there is a much better way of doing it. Do a search for clear tube and it will explain it.
Old Sep 21, 2003 | 10:18 AM
sixsixT's Avatar
This is the best way.
The best thing to do is check it before you take it apart, with a piece of clear tubing. You can get the tubing at a hardware store for 20 cents, 1/8" clear tubing.
Thu September 05, 2002 3:11 AM
The quick & easy way to check float levels is to use a clear tube that fits the dump hole on the bottom of the carbs. You'll need at least one foot of tubing. Don't worry about an exact fit, the tubing can be a little bigger which will cause some of the gas to leak out but gravity is forgiving and is constant! You can get the tubing from your Yamaha dealer for a few bucks. Remove the stock dump hole tubing, put the new tubing on there & then bend up the other end and run it along side of the carb with the open end facing up. Then open the drain screw next to where the tube is connected & the level of gas in the tube should fill up & be level with or slightly above the bottom/top half of the carb's mating surface. If not, you'll need to adjust the float levels. A sign that the float levels are too high is if the stock drain tubes leak gas while your riding, you'll smell it for sure.
I just pop the carbs on the boots and set the tank on the frame and hook up the hose to check it again, you may have to take it back off once or twice to get it perfect. I also measure the amount that it is off and then take it apart, measure the float height and then bend the tab enough to raise or lower the float the amount that it was off. If that makes any sense.
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
wrencher82
Sep 24, 2015 03:39 PM
black_thunder
Sep 22, 2015 07:59 PM
