blaster electrical/lighting
Old Sep 23, 2003 | 11:14 PM
roosthrower's Avatar
Default blaster electrical/lighting
yesterday my front and tail lights were working fine but tonight when I turned on my lights neither of them worked. Does anyone have any suggestions on how I might fix this problem? I'll retrace the wires tommorow to see if there is a loose connection for starters. Any other suggestions?
Old Sep 24, 2003 | 01:59 PM
NDCRFAN's Avatar
Taking a voltage reading with a multimeter is the first thing you should do assuming your bulbs are good. Always go to the last known source of power first, then proceed through wiring until you get no reading. At that point you should have traced down your problem to a broken wire, bad connection, disconnected wire, or a defective switch or other component.
Old Sep 24, 2003 | 04:08 PM
BUDXXX's Avatar
Fuse maybe?
Old Sep 24, 2003 | 05:22 PM
BLASTERDEVIL2's Avatar
check the connections under the headlight. mine goes out if I land to hard.
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
315blaster
Aug 8, 2015 08:13 PM
