tires for a zilla
Old Sep 25, 2003 | 11:00 PM
85lt250r's Avatar
Default tires for a zilla
my zilla came with 23x7x10 razars on the front and i dont like them, they fold over in the corners way too much, even when i run a lot of pressure, such as 12psi. Can someone recomend a cheap tire that has a stiff sidewall and a square profile, somewhere in the 21X7X10 size, or somehwere ther about the size
these tires will be going on a stock suspension zilla with a 220lb rider. the bike sees a lot of time on the mx track, butt the tracks corners are slightly flatter then most. The consistancy of the dirt ranges in a wide range, from just disked 4-6 inches of looseness to in need of discing hardpack with abotu 1" of loosness on top.
any suggestions would be appreciated.
thanks,
Old Sep 26, 2003 | 12:40 AM
MalHombre's Avatar
take a look at Titan FastTrekker front tires. they look to have a pretty wide contact patch (squared off)
i hear they wander a bit at high speeds but for MX it might not be a problem.
inexpensive too!
Old Sep 26, 2003 | 04:09 PM
No2StrokeBs's Avatar
I would suggest the shorter 19in holeshot MX tires. Thats what I run on my Zilla and they are great, turn like a champ. If you want to stay with a 21 in tire that is square and stiff, then the Pure Sport Bandit fronts are the way to go, they are hard as hell and square.
Here is a pic of my Zilla with the 19in Holeshots.
http://www.ls1camaro.net/freehosting/Zilla2.jpg
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
PinkFloydEffect
Sep 25, 2015 06:31 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
cboler9
Sep 24, 2015 08:35 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
