Quest 650 Transmission problems?
Old Sep 26, 2003 | 03:10 PM
rennym's Avatar
Default Quest 650 Transmission problems?
All,
My mechanic friend is ripping apart a Quest 650 tranny at the moment, and wanted to know if there is any common problems with the transmissions.
I searched for a bit, and couldn't find a common thread on transmission failures.
Anyone have one fail? Are there any common problems with them?
Thanks,
RM
Old Sep 26, 2003 | 08:38 PM
Gasser's Avatar
YES THERE IS A BULLETIN ABOUT SHIFTING PROBLEMS,SEE YOUR BOMBARDIER DEALER.
Old Sep 27, 2003 | 02:54 AM
rennym's Avatar
Anyone got the bulletin? Can they post it?
Old Sep 27, 2003 | 12:04 PM
rennym's Avatar
Bump
Old Sep 27, 2003 | 01:44 PM
Gasser's Avatar
202-6 & 2002-0007 CALL YOUR DEALER IT'S A FREEBIE
Old Sep 27, 2003 | 09:25 PM
javamom's Avatar
I have the same problem. They replaced my entire motor and tranny instead of fixing the problem. Now, i have a REALLY strange noise in neutral or high. Kind of a clatter. We are pretty sure it is going to die on us soon. Another motor is on the way soon, I hppe. We have ran it every weekend without any major issues, though.
Old Sep 28, 2003 | 02:09 AM
CanadianViking's Avatar
What year is the Quest? there were some problems with early 2002's, but I would expect that they would have all come to light by now.
Old Sep 28, 2003 | 02:12 PM
javamom's Avatar
Mine is a 2002 as well... however it should have an 03 motor/tranny combo now. The first problem was that it would not park. The shifter was off by one. Now... noise, noise, noise. In low it doesn't have that problem but it does in neutral if you rev it up at all and in high.
Old Sep 28, 2003 | 09:24 PM
so it makes noise in neutral and high, but not low?
Something in that new transmission must be out of adjustment - I would bring it back to your dealer and have them adjust the CVT. Good thing is that you can demonstrate the problem, so there shouldn't be much troubleshooting.
Old Sep 28, 2003 | 09:51 PM
javamom's Avatar
Yes - neutral and high but not low. We have been running it only in low for that reason. Don't want to blow it up.
They seem to just want to replace the motor. They don't have a lot of experience in the ATV dept yet. I will suggest that to them, though. I will be bringing it back tomorrow for the winch. We also seem to have several other problems... it stalls a lot after it is warmed up, today the odometer/speedometer quit working. It is backfiring on deceleration. I think they just need to tune it a bit and that will fix most of the troubles. [img]i/expressions/face-icon-small-smile.gif[/img]
greg74
Sep 10, 2019 03:03 PM
Captjay
Jul 23, 2015 12:33 PM
shewshew989
Jul 14, 2015 03:09 AM
shewshew989
Jul 14, 2015 02:54 AM
bikedad3
Jul 2, 2015 02:15 AM
