Bearing Numbers
Old Oct 1, 2003 | 10:35 AM
action450s's Avatar
Default Bearing Numbers
Does anyone know the bearing numbers for the Double Bearing for the Front CV Shaft in the steering knuclke???
Also need the bearing number for the rear wheel bearing for the rear, one that is mounted in the axle tube closest to the wheel on the side opposite the brake.
IF you dont know the number, do you know of any sites that may have it???
Honda factory bearings are too expensive, I can get them cheaper from another supplier if I know what the numbers are.
Edit: The bike is a '98 Honda Forman 450S
Old Oct 1, 2003 | 12:07 PM
TKBOB2000's Avatar
Well I have no idea what the numbers are .....but i would recommend to take apart the bike and take out the bearings then go to your local bearing shop and get the bearing there. I know I used to hate doing this cause you couldnt ride while the bike is apart, but the last couple of times my bearing shop had them is stock and I just went home and put her back together the same day.
We had priced bearings at the dealer and one bearing cost about 40-50 bucks... at the bearing shop i got the same beaing for 5-10 bucks.
ReconBayou
Oct 16, 2019 02:24 AM
exmotocrosser
Sep 13, 2019 06:12 AM
Johnny Mac
Aug 15, 2019 03:13 PM
jbrewster94
Sep 23, 2015 04:16 PM
