kfx 700 bulbs
Old Oct 2, 2003 | 12:32 AM
HUNDREDSPKBALLER's Avatar
Default kfx 700 bulbs
anyone know what headlight bulb the kfx 700 takes. not from kawasaki.
also, has anyone put brighter bulbs in yet. how many watts, any problems???
i want to put in a set of blue 100 watt bulbs but i dont want to mess up the electrical system or melt the headlight enclosure or anything like that.
hundredspk
Old Oct 2, 2003 | 08:17 AM
trx450's Avatar
Don't think 100W bulbs will work. They will probably melt the lamp housing. The system output will be taxed with 200WATTS of headlamp load,too.
Old Oct 3, 2003 | 05:40 PM
therock's Avatar
Copied from another thread.
Steelhead found a replacement headlight bulb that has a higher wattage output, is much cheaper, and fits the same as stock.
The stock is a 45/45w bulb, However this one says 65/55w.
The Bulb is from NAPA and is a Wagner 6260A
Steelhead and others have been using this bulb successfully without any damage to their headlight lenses or housings for quite some time. This bulb has a heat reflector to keep it from melting the lens.
I called NAPA on the lamp and they seem to thing the A designation means Amber. They said if I order and don't want them I have to keep them. A pre pay thing.
Old Oct 3, 2003 | 07:23 PM
i have been doing some looking on other sites and it seems that an H-4 bulb will work. the h4 is a very common bulb that is at any auto parts store for around $8.00 or less.
i have found these in two wattages 80/100 & 60/55
i plan to try the smaller one and will post the results.
hundredspk
Schneider
Jul 24, 2015 05:05 PM
Rob4092
Jun 15, 2003 07:53 AM
SMBLACKNIGHT
Feb 5, 2001 11:16 PM
offroader0794
Jan 24, 2001 03:57 PM
Arcosanti
Dec 30, 2000 02:04 PM
