scrambler tie-rod ends
Old Oct 11, 2003 | 10:54 AM
scrambler420's Avatar
Default scrambler tie-rod ends
hey guys,my outter tie-rod ends are junk,once again.i just replaced them 4 months or so ago,why do they keep going bad?i ride really hard through the trails,am i just to rough on it?i took the tie-rods off,and on the innner ends i cant get the bolt out,is the bolt and end one piece?thanks for any help..
Old Oct 13, 2003 | 09:55 AM
someone please help
Old Oct 13, 2003 | 02:22 PM
BigBadScrambler's Avatar
I dont know, I still have the stock old "crappy" design ones on mine and they are still tight. You must really ride it hard
Old Oct 17, 2003 | 12:45 AM
IMPORTH8R's Avatar
Those tie rods suck! I used female 1/2-20 rod ends on my 400 scrambler and my buddies 250 TB. I just drilled the holes oversize to 1/2 inch in the spindle and the stem and put 1/4 inch tall spacers under the ends at the spindle. Shim the inner ones tight in the stem with washers or spacers and use good grade 8 bolts for everything. This was way cheaper than using the polaris parts( at around $50 per end) I think I have about $60 in all 4 ends and the hardware. This setup has far outlasted the original tie rods, they were loose after about six months and ready to kill after about nine mo. I do ride ride mine pretty much every weekend though.
Old Oct 17, 2003 | 02:45 AM
ScrambleMe's Avatar
Is it possible to replace them with the 99, or 2000 parts?
I've put some rough miles on mine and all is still fine.
switzomatic
Aug 24, 2015 12:57 PM
mitchxc700
Aug 19, 2015 02:41 AM
scram5050
Aug 19, 2015 02:19 AM
maxjung
Jul 13, 2015 05:11 PM
