Oil Pumps on 650
Old Oct 12, 2003 | 03:30 PM
Kawi650's Avatar
Default Oil Pumps on 650
well I just replaced my oil pump 2 weeks ago and I believe it broke into 2 pieces again. what can cause this? What should I be looking at?
Old Oct 12, 2003 | 03:45 PM
newbeatle's Avatar
from what I know, there have been a few, but low numbers of problems with the oil pump, & most seemed to have been on "new" machines... perhaps there is something worn, that is causing the pump failure... if it is breaking/ cracking, it it probably getting viberation, thrust, or side stress that is not normal... I don't have my manual here with me, but I'd start looking for worn bushings or bearings that drive the pump... possibly a stuck pressure relief valve... but I'd suspect the bushings or bearings 1st....WAM
Old Oct 12, 2003 | 07:40 PM
nyroc's Avatar
Hard objects in oil that get by the screen could hurt the pump like that.
Using 20w50 dino oil in cold weather might stress it a bit more. Like newbeatle said, the relief valve is the oil pumps best friend and life support.
What cracked? The rotor (center gear thingy), the outer ring thingy, the shaft, the housing?
what oil do you use?
Old Oct 13, 2003 | 12:13 AM
Kawi650's Avatar
I'm using the Kawi oil right now... but I was on the motul before both oils is good on mine point of view. "The rotor (center gear thingy)" broke on both sides. but I replaced the shaft last time to do some preventive maintance.
Old Oct 13, 2003 | 11:56 PM
wildwill's Avatar
Kawi650,
How can you tell if your oil pump is broken? Did it make alot of noise?
Thanks
exmotocrosser
Sep 13, 2019 06:12 AM
BYC
Sep 25, 2015 02:10 PM
rockinkgin
Sep 25, 2015 01:52 PM
Sw00p
Sep 24, 2015 02:50 PM
