Dune gearing
Old Oct 14, 2003 | 05:25 PM
racereadyraptor's Avatar
Default Dune gearing
I have already installed a -1 tooth from my front sprocket....Do I need to do somethimg to the back to compliment this change?I am mostly about
shooting the hill at Glamis.
Old Oct 14, 2003 | 05:28 PM
raptor03's Avatar
If your stock a 12 tooth will get you up the hills at Glamis just fine,if you have mods besides the pipe and filter then the 13 is working good..
Old Oct 14, 2003 | 05:33 PM
I'll have my Sparks X-6 by then.I also have a bad a$$ air box eliminator made by SixsixT!!
Im going to have Kenz dyno tune it for me as well.Would you suggest the 12 or 13?
Old Oct 14, 2003 | 08:00 PM
raptor03's Avatar
I am running the same set up and the adaptor with a yosh but i weigh 200lbs,if your lighter than that like 160 and under the 13 might be fine but i bet the 12 will get you there faster,i would go with a 12
Old Oct 14, 2003 | 10:10 PM
sixsixT's Avatar
I'm running a 13/43 which would be the same as 12/40 with 20" tires.
Old Oct 14, 2003 | 10:14 PM
kingron's Avatar
I have a stock 02 LE and last year I put the 12 tooth on. It made a world of difference in the sand. It works just as good in the desert too.
bigbear350quad
Sep 11, 2015 12:40 PM
John Reed
Sep 9, 2015 03:46 AM
poutlaw525
Sep 9, 2015 03:19 AM
awer1968
Sep 8, 2015 11:02 AM
