Is a warn 2000 enuf
Old Jun 11, 2000 | 12:31 PM
stevie's Avatar
Im buying a winch soon and i was wondering if a warn 2000 would be good i think it would be but im new to this winch thing.
Btw whats the bolt pattern of polaris rims.
Old Jun 11, 2000 | 01:46 PM
Jaime's Avatar
a 2000 lb winch is enuf but more is somtimes better He HE seriously it will work fine maybe look into a ****** block for when you need more power . Also what polaris atv are you asking about there is two different patterns?
Old Jun 11, 2000 | 02:28 PM
stevie's Avatar
A 500 scrambler
Old Jun 11, 2000 | 04:40 PM
Tree Farmer's Avatar
Stevie, the Warn A2000 and A2500 share the same motor and geartrain; one handling the power with a rotary switch and one with a remotely-switched solenoid, respectively. With a ****** block, either should do the job for you. Heck, with a ****** block, even winches rated lower (e.g., 1500) will do the job. Good luck.
Tree Farmer
Old Jun 11, 2000 | 06:12 PM
BONER's Avatar
A 2000 lb winch will easily pull out a stuck Scrambler.
The bolt pattern for polaris is 4/156 front and 4/4 rear. This is on most models. Heavier polaris have the 4/156 in the rear also(Sporsman series, Ranger, and the Diesel.
Jeff Roper
Feb 1, 2022 11:48 AM
Gwolf228
Feb 18, 2017 01:36 AM
Dammar
Apr 20, 2016 06:03 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
panicmanic
Sep 28, 2015 12:59 PM
