Removing double off-set from front Differential on Kodiak 400
Old Oct 19, 2003 | 01:53 PM
Kodiakblues's Avatar
Default Removing Ball Joint from front Differential on Kodiak 400
Does anyone know how to remove double-offset from front Differential. I need to replace bearings in Front Differential. The book shows a circlip inside the housing .I would like remove them so I can drop the diff- thru the frame.
Thanks in Advance
Jeff
Old Oct 19, 2003 | 02:59 PM
shastadog's Avatar
Default Removing double off-set from front Differential on Kodiak 400
I just when outside and looked at an old front diff. I had out of a big bear.Looks to me like youcan slide the cv axles out if you have them loose from the wheel side. There didn't seem to be any keepers or any thing that would hold them from just sliding out.
Old Oct 19, 2003 | 04:33 PM
Thanks Shastadog
You didnt happen to notice if there is a circlip groove on the inside cv-joint(off-set).
Thanks
Old Oct 19, 2003 | 06:20 PM
shastadog's Avatar
I didn't see any. this big bear diff should be the same but I'm not absolutly sure. I think they just slide out. There may be spring clip on the diff end of the axle but it should slide out when you get it loose from the spindle end. Let us know how it goes
Old Oct 20, 2003 | 03:29 PM
Yes ShastaDog with a little bit of persuasion they did pull out of the differential. Now i will be able to drop it thru the frame. Thanks for your help.
Jeff
lightninboy
May 16, 2021 09:52 PM
jettman
Jul 6, 2015 12:16 PM
traumajunkie
Jul 5, 2015 03:03 PM
Shifts
Jul 3, 2015 07:59 AM
Mphillips
Jul 2, 2015 07:20 PM
