03 450es lower on 1 side
Old Oct 19, 2003 | 10:10 PM
butch1234's Avatar
Default 03 450es lower on 1 side
my new 2003 450es is 15mm lower on r/f side then l/s had it in at dealer to get checked and told it was normal!! can this be true?has anybody else noticed this and is there a fix?
Old Oct 20, 2003 | 12:17 AM
MDE3's Avatar
Did you measure the length of the rod coming out of the shock? If they are different lengths then there is A) either more weight on the lower side, or B) the spring tension is not equal on both sides. When you pick up your front end, is there some droop to the suspension? Meaning the wheels "drop down" in realtionship to the chassis? If so it is probably the spring tension, or the weight on the low side
Old Oct 21, 2003 | 09:26 PM
butch1234's Avatar
i measured all shocks even changed them from left to right same problem even with bike jacked up even in center still down on r/s same amount
Old Oct 22, 2003 | 01:31 AM
MDE3's Avatar
Is the right front wheel hanging lower when you support the bike on a stand? Or is the frame closer to the ground on the right front, or both? Is there any kind of adjustable sway bar on the front?
Old Oct 26, 2003 | 01:48 PM
butch1234's Avatar
frame is lower on r/s wheel hangs same distance no adjustment on the front anywhere
Joe454
Nov 20, 2020 01:19 PM
exmotocrosser
Sep 13, 2019 06:12 AM
badgerboy1
Sep 26, 2017 06:11 PM
Dunes and Dune Machines
Sep 29, 2015 09:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
