250 Mojave flywheel puller...HELP
Old Oct 20, 2003 | 08:11 PM
haywoodjalikme's Avatar
Default 250 Mojave flywheel puller...HELP
Does anyone know what the correct size the flywheel puller for a '88 250 mojave is?
dennis kirk list 2 diferent ones, a 35mmx 1.5 mm and a 30mm x 1.5 both seem too large to me and past orders of puller through them left me with 2 for a 200x honda and neither fit.
So I am hoping someone can help.
Thanks
Old Oct 20, 2003 | 09:13 PM
mahnster's Avatar
Try to PM boob because he just had a post about getting his flywheel off and he eventually got it.
Old Oct 20, 2003 | 11:32 PM
boob's Avatar
hey!, since i had such a hard time with mine and stuff i thought id try to help, well the flywheel puller is terrible!! i bought one off of denniskirk, oiled it, and impact wrenched it and eventually all the threads on the puller messed up really bad, so i bought a 2 armed puller from the local auto parts store (auto zone) and it has 2 arms and a bolt down the middle, well i got the arms around the back of the puller and put the main bolt assembly into the flywheel center and impact wrenched it and when it stopped i did it again, then i let off and reversed it out then impacted it again, but im gonna assume you dont own one, well you get a breaker bar or anytihng with a 1/2inch drive and the correct socket for the puller assembly and just keep going tightening it and when it becomes almost impossible to tighten hit the top of the puller with a hammer a god 5 or 6 times and then grab the puller and shake up and down and then try turning it a lilttle bit more, now undo the assembly and it should come right off, if this doesnt work the first time just keep repeating it and it shall work, if worse comes to worse take it to the dealer, my dealer is very stingy and wanted 40$ for it but they said it was so easy for them that they did it for free, good luck and if you need any help just ask, also dont worry about the threads inside the flywheel, they are practically indestructable, and the bolt is tourqued at 70foot pounds
Old Oct 21, 2003 | 07:10 PM
Thanks guys I'll give 'er a try, the old Mo is comin' apart this weekend(broke the reverse shaft and kickstarter gears)gotta split the cases[img]i/expressions/face-icon-small-sad.gif[/img] I hate that.
Old Oct 21, 2003 | 10:33 PM
boob's Avatar
wow, sorry to hear, i broke my second kick starter gear and just got electric start
Old Oct 22, 2003 | 07:41 PM
Boob where did you get your electric start and how much did it cost?
Thanks Jeff
Old Oct 22, 2003 | 10:30 PM
boob's Avatar
i got it from lurch for 130 but it retails for 475 i beleive by Goki mfg
Old Oct 23, 2003 | 08:59 AM
jeffksf3's Avatar
Yeah I remember pulling my flywheel off, it was a big pain in the A$$! I was able to do it with the flywheel puller. When using the puller you need to have a wrench that holds the flywheel, because otherwise you'll just turn the cranckshaft. While you are doing this be sure to install a new timing chain just to be safe. I had the Goki Elec. start on mine also and it worked pretty well.
Old Nov 3, 2003 | 10:48 PM
The correct size puller is a 18mm x 1.5mm right hand thread male, Denniskirk sells one for the Mojaves and it is a 35mm x 1.5mm female, not even close WTF?
All I know is that the pullers listed for the kawasaki mojave and the honda 200x at denniskirk are all wrong!
Old Dec 28, 2003 | 07:54 AM
Quadzei's Avatar
Hi fellows
i am new on this forum and from Germany. I buy a few months ago 96 mojave. Is that right , there is an aftermarket electric starterkit for the moj . Any information welcome.
See you
chingchangchong
Aug 7, 2022 11:36 AM
Joe454
Nov 20, 2020 01:19 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
raman8tor
Sep 20, 2015 07:35 AM
