3 headlight high beam kit?
Old Oct 22, 2003 | 02:57 PM
dirtbikejunkie's Avatar
Default 3 headlight high beam kit?
Has anyone used one of the kits that are being sold on ebay that turns all three headlights on when you switch to high beam? What does the kit consist of? Is there any problems associated with running all three head lights together? Does anyone know if this type of kit will work on my 92 Trailboss 350L 4x4?
Thanks,
Dirtbikejunkie
Old Oct 22, 2003 | 05:32 PM
wagntwister's Avatar
Anybody know? I am also intrested.
Old Oct 27, 2003 | 04:57 PM
Surly someone out there has bought one of the headlight coversion kits off of ebay that is supposed to turn on all three headlights when you go to high beam. I would like to know if it helps a lot and if there is any problems with the wiring overloading. I would like to add one to my 92 Trailboss 350L 4x4.
Please help out if you can!
dirtbikejunkie
Old Oct 27, 2003 | 06:18 PM
yoopermike's Avatar
I bought the kit sold by montana jack's. no problems at all....works great! I put it on my sp700 and will also be doing it to my sp400.
Old Oct 27, 2003 | 06:52 PM
lovemud's Avatar
I just used a toggle switch, I turn on the lights (either high or low) with the toggle on it powers all 3. with the toggle off it work normal. That way I can turn it off and run high only if I want to run some other accessory instead. Just splice your toggle switch into the leads for both the high beams and low beams, and it cost $0.79 cents.
Joe454
Nov 20, 2020 01:19 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Whitelx1
Oct 2, 2015 10:55 PM
r1pilot83
Sep 27, 2015 07:38 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
