3 headlight high beam kit?
Has anyone used one of the kits that are being sold on ebay that turns all three headlights on when you switch to high beam? What does the kit consist of? Is there any problems associated with running all three head lights together? Does anyone know if this type of kit will work on my 92 Trailboss 350L 4x4?
Thanks,
Dirtbikejunkie
Thanks,
Dirtbikejunkie
Surly someone out there has bought one of the headlight coversion kits off of ebay that is supposed to turn on all three headlights when you go to high beam. I would like to know if it helps a lot and if there is any problems with the wiring overloading. I would like to add one to my 92 Trailboss 350L 4x4.
Please help out if you can!
dirtbikejunkie
dirtbikejunkie
I just used a toggle switch, I turn on the lights (either high or low) with the toggle on it powers all 3. with the toggle off it work normal. That way I can turn it off and run high only if I want to run some other accessory instead. Just splice your toggle switch into the leads for both the high beams and low beams, and it cost $0.79 cents.
