how to set timing?
Old Oct 26, 2003 | 05:17 PM
lilnotts's Avatar
Default how to set timing?
well i'm going to be puttin my topend back together tonite, just looking for any tips on settin the timing(which is the reason it had to be tore down[img]i/expressions/face-icon-small-sad.gif[/img]), wat stroke should it be on at TDC?
Old Oct 26, 2003 | 05:25 PM
Hurycne's Avatar
As long as the piston is at top dead center and the cams are alined you will be fine. Top dead center is top dead center
Old Oct 26, 2003 | 05:42 PM
PUSHINTHELIMIT's Avatar
Put it at TDC and make sure the cam lobes are OPPOSING each other....
Old Oct 26, 2003 | 05:45 PM
lilnotts's Avatar
can the cam come off the crank sprocket if the chain isn't held tight enough and then come back on wen it is pulled tight?
Old Oct 26, 2003 | 05:48 PM
And like hurycne said, TDC is TDC as long as the cam lobes are opposing each other and the timing marks lined up you're good to go! Pisst, lilnotts.... Don't bend no more valves..[img]i/expressions/face-icon-small-wink.gif[/img]
Old Oct 26, 2003 | 05:50 PM
I'm not sure about your last question but just check the marks after you have the tensioner on and ready to put the cover back on...
Old Oct 26, 2003 | 05:52 PM
lilnotts's Avatar
well i'm just trying to figure out how i bent them the first time, and thats the only thing i can come up wit, must moved a tooth on the bottom
Old Oct 26, 2003 | 05:54 PM
MudStud's Avatar
I would put in a TDC bolt in the crank!!! I did that, you never know if it may move. I always do that!
Sjrpp
May 2, 2023 03:59 PM
slowgsxr97
Mar 18, 2022 03:40 AM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
95wolv
Jul 17, 2015 08:13 PM
