excessive heat
Old Oct 30, 2003 | 03:54 AM
Nickli's Avatar
Default excessive heat
Ok, heres what happened to my 400ex. I bought it used. Shortly after that, the top end got way to hot from not enough oil. So, I took it in, had it bored to clean up the bore, Wiseco piston instelled. Ran fine until too much dust messed up the bore. Now Im going in for another bore. If when it got too hot the first time, is it possible that the cylinder head was in any way fatigued so that no matter how many times the bore is cleandd up it will still have a short life for each additional bore. Its only been bored once. and it was a minimal bore to clean it up?
Old Oct 30, 2003 | 09:58 AM
extremerider2811's Avatar
get a new top end
Old Oct 30, 2003 | 03:07 PM
Nickli's Avatar
Im having the piston kit done. But I wonder if the cylinder needs to be replaced due to excessive heat.
Old Oct 30, 2003 | 11:31 PM
whatwasthat's Avatar
i hope you're washing out that cylinder with warm soapy water before you install it....
Old Nov 3, 2003 | 02:07 AM
BSA's Avatar
BSA
What does bored to clean up the bore mean? Do you mean it was simply honed or do you mean it was taken to the next over size?
If you are letting dust get into the engine you will have to over-bore and/or resleeve constantly. Are you running with no air cleaner at all?
Jeff Roper
Feb 1, 2022 11:48 AM
2many2ride
Sep 27, 2015 04:35 AM
Sw00p
Sep 24, 2015 02:50 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Jeff Roper
Sep 21, 2015 02:11 PM
