installing prim & sec springs 04 sp600
Old Nov 2, 2003 | 03:40 PM
400sp's Avatar
Default installing prim & sec springs 04 sp600
is there a place i can download a manual showing the way to install my new dalton primary and secondary springs for the clutch, i need torqe specs on both to, ive never been inside the cover but was told it was easy to do.
Old Nov 2, 2003 | 05:15 PM
Mark82ndABN's Avatar
Two days ago I installed a Team Performance secondary clutch and changed out the primary clutch spring and weights on my new Sportsman 700. I took some pretty good digital photos of the "work in progress". E-mail me if your interested and I will e-mail you the pictures ( mncreid@epix.net ). I had never been in the cover either before this and it was very easy.
Old Nov 2, 2003 | 05:55 PM
pest44's Avatar
Try here.
Old Nov 2, 2003 | 07:22 PM
400sp's Avatar
thanks pest44 ,just what i was looking for,steve
Old Nov 3, 2003 | 08:37 PM
400sp's Avatar
thanks mark for they awsom pics,have you tried your new set up yet? inform me please!!
Old Nov 3, 2003 | 09:38 PM
Hi 400sp,
I have not gotten out to the trails yet but I did try her out on some dirt roads and in a field near by. All I can say is I'm loving it!!! The up shifting and back shifting is flawless and there is a very noticeable difference in acceleration. The power being delivered to the ground is much stronger now and the bottom through mid range hit is certainly quicker. I did notice that the clutch now engages at a SLIGHTLY higher RPM which is hardly noticeable in high gear but in low gear you will want to ease into the throttle when taking off and even at that she's a bit jumpy. You may think "that's cool" but if your doing any technical rock crawling I'm afraid she might be to jumpy if your not careful. I'll get use to it I'm sure....this is the ONLY somewhat negative thing I've found. I would HIGHLY recommend this set up. Give Hot Seat Performance a call and they'll hook you up (and NO, I do not work for them. They were just very easy to deal with and were very helpful).
Old Nov 4, 2003 | 09:10 PM
400sp's Avatar
mark,thanks for the update, i just installed my new prim. & sec clutch springs tonight on my 600sp from dalton ind. and just trying it out in the drive way, its got more bottom end, i lost a little when i put 26 589s on so i think ill be happy with the set up, well see this weekend, it took me about 40 mins., no problems at all, keep in touch,steve
Old Nov 4, 2003 | 09:46 PM
Hey Steve,
You're faster than I am.....took me a little over an hour to do mine. Good to hear you already notice a difference. Let me know how she works out this weekend, Mark.
Old Nov 4, 2003 | 10:18 PM
400sp's Avatar
mark, i did cheat alittle, i used air tools when i did it except for retorqing the bolts, dont feel so bad!!!talk to you soon,steve
ReconBayou
Oct 31, 2022 05:37 PM
shimanok2
Jan 29, 2016 07:37 PM
2many2ride
Sep 27, 2015 04:35 AM
toonces
Sep 5, 2015 01:14 PM
