Finally got around to checking my valves... Results.
Old Nov 2, 2003 | 07:01 PM
TyreSpinner's Avatar
Default Finally got around to checking my valves... Results.
Left Exhaust
.152 mm (0.006)
Right Exhaust
.076 mm (0.003)
Left Intake
.102 mm (0.004)
Right Intake
.064 mm (0.0025)
What do you guys think?
And by left, I mean the closest to the timing gears.
Old Nov 2, 2003 | 07:09 PM
SANDMAN430's Avatar
looks a little tight on the right.
Old Nov 2, 2003 | 07:33 PM
Is it normal for it to be tigher on one side than on the other?
I'm assuming this requires attention ASAP?
Old Nov 2, 2003 | 08:18 PM
Eaglecollector's Avatar
Don't know about it being normal or not. Mine seemed to always tighten up on the intakes only when i had the stock valves. And yes it needs attention or you may burn a valve if it goes un corrected for long. They will only get worse.
Old Nov 2, 2003 | 09:48 PM
ThePunisher's Avatar
INtakes at .006 and exhaust at .008 that is were they need to be.
Old Nov 3, 2003 | 04:26 PM
Thanks Guys,
I'll let a bomb tech do the adjusting. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Nov 3, 2003 | 05:23 PM
TwistedPiglet's Avatar
If you already have your motor far enough apart to check the valves, it's not that much more to change out the shims. Just take the shims out and place each one in a bag and mark where it came from, LF, RF, LR, RR or whatever. Then go to a BMW dealer or a Bombardier dealer and have them check which size each is if you don't know already and get whatever the difference is that you need. If they mic out at 2.45 and it needs to be .05 thicker, get the 2.50 and put it in. Then for the next time you will know what shim size you have in there already so when you check the valves you will know what size you need to go get.
Dustin
slowgsxr97
Mar 18, 2022 03:40 AM
ghost civic
Jul 20, 2015 12:36 PM
ghost civic
Jul 19, 2015 10:13 AM
HondaR24
Jul 16, 2015 10:45 AM
Bob Maurice
1) Engine problems..
Jul 14, 2015 09:05 AM
