Problems with TrailBoss 330
Old Nov 3, 2003 | 03:02 PM
hsach's Avatar
Default Problems with TrailBoss 330
Hello, my '03 Trailboss is only a couple of months old, probably less than 20 hours on it. Yesterday I rode it for the first time in cold weather, around 35 degrees. I couldn't get the atv to idle at all, everytime I would let off the gas it would stall no matter how long it was running. Also, when I would let off the gas it would backfire, it never did this before. What are some things I should check for? Never had an atv before so I am not sure what could be causing this. It also seemed to have a little less power than normal. Is it due for a tune up, or is there some 20 hour service I am supposed to do? Thanks for any advice.
Old Nov 3, 2003 | 03:15 PM
Bradracer18's Avatar
hsach, my guess is that your quad was running well in the warm weather and now badly in the colder weather. Is that correct?? if so, then i would guess that you need to re-jet your quad. I think, not for sure, that you need to go to a smaller jet. Hopefully someone will double check my answer here, and give me a way of remembering the jetting "system." well i hope that helps some. Brad
Old Nov 3, 2003 | 05:42 PM
markbanger's Avatar
How much stuff is on your key ring?
Old Nov 3, 2003 | 05:57 PM
Bustedparts's Avatar
It sounds to me that you have to much throttle free play or your throttle over ride system is messed up.You should have 1/8th to a 1/4 inch of play in the throttle .Any more than that and you will get the problems you are having.Adjust it and go from there.
Old Nov 3, 2003 | 06:25 PM
hsach's Avatar
The only thing on my key ring is the one key to start the quad. I will check the throttle cable for slack, hopefully this will do the trick. Thanks.
Old Nov 10, 2003 | 02:18 PM
hsach's Avatar
Just an update to my problem. It's fixed! As soon as I adjusted the throttle cable she purred like a kitten. Thanks to everyone who replied, saved me a trip to the shop. No more stalling or backfires. Now I have to decide if I want to take it back in for the 20 hour service or just do it myself, it's probably not hard but I am becoming more and more lazy. Thanks again everyone.
Old Jan 28, 2004 | 01:29 PM
Jaycee1964's Avatar
How is the throttle cable adjusted? atthe carb. or on the thumb throttle? mine is roough to warm up and backfires when cold too.
tks,
John
Old Jan 28, 2004 | 01:47 PM
markbanger's Avatar
there is an adjustment on the carb and on the throttle cable. Try to adjust the one on the cable first.
Old Jan 28, 2004 | 01:48 PM
markbanger's Avatar
On the cable you will see a spot were you can fold the rubber back. under that there will be an adjustment.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
