Crank Welding
Old Nov 5, 2003 | 02:58 PM
JakalWarrior's Avatar
Default Crank Welding
Is it done before or after the crank is assembled and can it be done after its assembled? This is for my RD which is essentially a banshee crank except for the flywheel side taper.
Old Nov 5, 2003 | 04:12 PM
warrior007's Avatar
After, on the crank pin so the crank does not twist on a built or stroked motor.
Old Nov 5, 2003 | 04:16 PM
Isint the rod in the way though?
Old Nov 5, 2003 | 04:23 PM
warrior007's Avatar
there is a picture of a welded crank about 3/4 down this page, its welded from the side.
If you think of the crank pin as a pivot point and how the whole crank could twist on that pin you can see why welding the crank to the pin would stop it
Old Nov 5, 2003 | 04:27 PM
Ok I get it now. For some reason I thought they welded it on the inside side. Guess Ill go ahead and get it done. I read somewhere that it messes up the alignment though, is that true?
Old Nov 5, 2003 | 04:30 PM
warrior007's Avatar
Done right it shouldnt mess anything up or they wouldnt do it. Have a shop look at it first to make sure its true, then have them weld it.
pgamboa
Dec 24, 2023 11:52 AM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
QuadRiders
Oct 22, 2015 04:13 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Jackg17
Sep 26, 2015 09:30 PM
