PREDATOR POPPING CDI
Old Nov 7, 2003 | 03:18 PM
Fixitmatt's Avatar
Default PREDATOR POPPING CDI
WELL I have Found the rev limiter.I tried jetting it but, it wasn't the cause of the backfiringand popping!
SO now I'm at that point where I don't know what to do>
FRIST OFF WHY IS tHAT REV LIMITER SO DAM LOW!!!!!!
I HAVE never hit a rev limiter on a yamaha RAptor, Even One that is highly modded. What is up with that.Polaris needs to fix this>
Anyway What kind of CDI can I get? I'm not looking to spend A ton of money For a Cdi with tons of Curves.
What kind of prices Am I looking at. anyting Less then a HPD One.
Also Maybe one of you Knows If you can just cut the wire that controls the rev Limiter. If SO what Colour wire is it>
I only have a slip on W/b silencer Dyno jet kit and K+n filter and I don't need much more other then a little higher rev without popping
HELP me!!!!!!
Old Nov 7, 2003 | 04:31 PM
Fixitmatt's Avatar
COME ON GUYS I Know someone can help me!
Old Nov 7, 2003 | 05:06 PM
propolaris's Avatar
dude polaris put the rev limit on the predator so you wont float your valves. i installed vortex cdi on mine and stronger valve springs well worth the money.
Old Nov 7, 2003 | 07:48 PM
IBlameTheDog's Avatar
To be honest with you I believe that the rev limiter is kinda low as well and do not like it but, I have found that if I shift before I get close to it the bike just keeps pulling and is faster than if I ride the border of the limiter. If you can, try short shifting a little bit, if not Rath, Vortex and others offer an aftermarket box. Good luck!
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Dunes and Dune Machines
Sep 29, 2015 09:35 AM
r1pilot83
Sep 27, 2015 07:38 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
