trail blazer in the mud!
Old Nov 9, 2003 | 12:43 AM
BT250racer's Avatar
Default trail blazer in the mud!
hey guys i have a 1999 trail blazer with titan 489 xts and i goes good in the mud until the water goes into the clutch and the belt starts to slip is there a way to moddify the clutch intake so it dont. i know u cant block off the air b/c the clutch would get to hot but is there a way to just to close it up when your in the mud and open it back up when your not.
1999 trail blazer
titan 489 xts back
maxxis razers front
k&n filter, handle bars, grips
12t front 36t back sprokets
bash gaurd,pro burner lights
neon shifter,D.I.D racing chain,rebuilt trans
things i made
stronger back caliper holder
custom brake light
pin strip grapichs with black checkers
skid plate, grab bar
Old Nov 9, 2003 | 12:58 AM
talonhawk's Avatar
The clutch air intake is up pretty high so you must be
riding in some deep water. Are you sure that the water is not
coming in from the seals? I would not block the intake off
because the clutch generates a lot of heat pretty quick and
you are only asking for trouble!
Old Nov 9, 2003 | 01:11 AM
BigBadScrambler's Avatar
You would have to be in water up to your seat to have come in through the intake. I agree with Talonhawk. Check your seals first. If you are unsure, fill your clutch housing up with water and check to see where it leaks out from. Make sure to blow the water out of the clutches afterwards
Old Nov 9, 2003 | 02:15 AM
Trailblazer250exrexr's Avatar
and if it is leaking from there get a new gasket that goes around there or ni66er rigget some how
Specta
Family ATVing Photos
Dec 7, 2018 08:22 PM
Alex Rodak
Sep 11, 2015 11:42 PM
craacker
Sep 9, 2015 04:32 AM
awer1968
Sep 8, 2015 11:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
