Shifter problem with a 1999 Magnum 325 4x4
Old Nov 13, 2003 | 12:25 PM
robnhouston's Avatar
Default Shifter problem with a 1999 Magnum 325 4x4
A buddy has this atv and has just started having some problems with it. Problem is when he shifts it into forward and takes off it'll kick back into neutral in 20-30 feet. If he holds the shifter with his foot it'll stay in gear.
Haven't had time to look into it yet. I was hoping yall could give me some ideas or if someone has experienced this before.
Thanks,
Rob
Old Nov 13, 2003 | 01:21 PM
4wheelitis's Avatar
Robin,
check the adjustment rods for the shifter, one is just slightly out of adjustment, it may only take a quarter turn or less. The inside rod controls low forward, the outside rod controls High. Good Luck
4wheelitis
Old Nov 13, 2003 | 07:24 PM
ftwflh's Avatar
Like I have said before check the oil in the shifter ,the rod adjustment ,and the alluminum shift levers on the tranny.If these dont do it the shift fork in the tranny is wore.Oh yea check the idle too.It could also be the primary clutch not releasing all the way too.It can get complicated but check the eaasy things first.
Old Nov 14, 2003 | 09:08 AM
quadwrench's Avatar
This may seem too simple - but I have seen 'em not shift due to low or no lube in the tranny.
Old Nov 14, 2003 | 12:08 PM
SnowPolarisATVDealer's Avatar
it might be you linkage adjustment or it could be a bearing or somethign inside you transmission.........check the linkage first....and it you cant get the linkage mess with it for a while cause it is sorta hard to get it if you havent done it before
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
Schneider
Jul 24, 2015 05:05 PM
hondarider1234
Jul 21, 2015 11:53 PM
jettman
Jul 6, 2015 12:16 PM
