tire question for prairie700
Old Nov 18, 2003 | 11:26 AM
prarie700's Avatar
Default tire question for prairie700
hello all i am new to forum and i have a tire question? i have an 04 prairie 700 and just bought 27" mudlites on c-series wheels. do i need to put a new spring in the clutch or will the stock one be ok?
thanks.
Old Nov 18, 2003 | 11:45 AM
logger's Avatar
Prarie 700, I have the same set up on my p700.400 mi.on it and all is working good. hope you like your p700 as much as i do.you should look in to a new set of skid plates if you ride rough, the stock one are like tin foil. i put on a full set of ricochet, thay went on easy and work well in the mud around here. good luck.
Old Nov 18, 2003 | 12:22 PM
prarie700's Avatar
logger, thanks for the reply. yes i love this machine incredible power. where can i find info on the skid plates? i am looking to replace because you are right they are flimsy.
Old Nov 18, 2003 | 12:30 PM
MikeRhyne's Avatar
That is the same wheel/tire set up I just put on mine and can't wait to ride it more than on the street - hopefully this weekend. I got my skid plate at http://www.4atvtires.com/ as they were one of the few that state the skid plate fits the 700. I'm planning on doing some clutch/spring work just to help protect the belt.
Old Nov 18, 2003 | 01:53 PM
logger's Avatar
prarie700, atvoutfitters.net has them.
Old Nov 18, 2003 | 01:56 PM
logger's Avatar
mike r. what is a progressive front end? thank you.
Old Nov 18, 2003 | 02:20 PM
MikeRhyne's Avatar
The progressive front end is the adjustable front spring kit that I put on. It really helps the ride and load carrying capacities. Thier info is at http://www.progressivesuspension.com/31-series-atv.html . I got them off of ebay for $115.
Old Nov 18, 2003 | 02:29 PM
prarie700's Avatar
mike, how much better is the progressive front end vs. the stock?
Old Nov 18, 2003 | 02:37 PM
MikeRhyne's Avatar
That is kind of a subjective question but here is my opinion. I like it allot better it got rid of the nose dive and gave me a better more sporty ride. Depending on what you do it may or may not be right for you. I carry 3.5 gallons of gas on my front rack which is why I got it - to retain a good ride under load. I just put it on and have only one ride with it and no real rides on it with the new tires...
Enjoy!
Old Nov 18, 2003 | 04:02 PM
trx450's Avatar
The Progressive Kit, along with "real" tires, will get rid of that "Prairie Push" in the front end. You, know , that feeling that the outside frt. tire is just gonna' peel off the rim in a sharp, high speed turn!
IMO the best mods you can make to a Prairie 650/700 are :#1 TIRES! #2-the EPI "black spring" for the driven(secondary) clutch #3-Progressive frt. springs #4-- a good exhaust/jetting/air filter
Enjoy your new toy.....I am on my 3rd V-Twin Kaw.
