Plug Reading
Old Jun 17, 2000 | 11:56 PM
will's Avatar
How do you do a plug reading on a 2 stroke to see if the jetting is correct??
Old Jun 18, 2000 | 01:01 AM
fourlix's Avatar
First make sure you're up to operating temp. Then run it hard- wide open full throttle sprints. Then
stop quick, with spark plug wrench waiting, pull plug. If it is black and sooty, and was running doggy, you are too rich and need a smaller main jet. If it is chocolate to tan you are right on.
If it is white, or there are little tiny beads, that is your piston melting, you are too lean, and it will have been running real good, but might have been running on, like not throttling down, like it was possessed, and Scotty, shes gonna blow sky High!!
Silly Later, Fourlix
SP500,425EXP,325Mag AutoCat500 For Sale
Old Jun 18, 2000 | 08:25 AM
kreid818's Avatar
This is correct but there are a few more tips. First when you do the "jetting run" you must keep the throttle open when you kill the motor otherwise you will get a incorrect reading. Secondly you can do this in 4 part of the throttle because you have 4 speed circuts in the carb (0-1/4 1/4-1/2 1/2-3/4 3/4-full)
Big bousse
Sep 26, 2015 10:42 AM
Nondem
Where to Ride
Jul 23, 2015 07:38 PM
Captjay
Jul 23, 2015 12:33 PM
ltrmc02
Jul 22, 2015 04:50 AM
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
