When to switch to Synthetic Oil
Old Nov 19, 2003 | 09:58 AM
Duramax's Avatar
Default When to switch to Synthetic Oil
How much time or miles do you need to put on a bike before you switch over to synthetic oil? What is a good break-in time? Thanks
Old Nov 19, 2003 | 10:05 AM
DeuceRooster's Avatar
Run about 10 hours on dino (regular) oil then switch to synthetic.
Old Nov 20, 2003 | 01:25 PM
L&S's Avatar
L&S
hey duramax, deuce rooster is right. You just need enough hours on the motor 2 let the rings set properly. Try it in your truck you will be amazed at the difference in mileage. Amsoil, or royal purple . I have had luck with both.
Old Nov 20, 2003 | 01:28 PM
NotuRaptor2's Avatar
AMSOIL makes a specific 4 stroke synthetic oil that works with a clutch setup (doesn't have any friction type modifiers added).
/Jon
Old Dec 1, 2003 | 01:03 AM
cluby's Avatar
Hey don't put any sythetic in any of the honda's with auto tranny's
Old Dec 1, 2003 | 12:21 PM
MDE3's Avatar
Unless it is a specific 4 stroke oil desigened for common lube of tranny/clutch and motor, do not use it. It will cause the clutch to slip if not specifically designed for this application.
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
nick c
Sep 13, 2015 10:08 AM
alzgarvin
Sep 11, 2015 08:53 AM
MrTrashMan2U
Sep 9, 2015 11:11 AM
toonces
Sep 5, 2015 01:14 PM
