ARGH HELP!!! Pred rear sprocket removal
Old Nov 29, 2003 | 10:43 PM
Sceiks's Avatar
Default ARGH HELP!!! Pred rear sprocket removal
When you guys changed out your rear sprockets what did you have to do to get it off the sprocket hub? Did you have to masage the hub or sprocket with a grinder [img]i/expressions/face-icon-small-confused.gif[/img] or did you have to take the whole axle assembly off? At this time it looks to be about a little more Than an 1/8th of an inch total of material i would have remove. (1/16th+ on each side)
Old Nov 29, 2003 | 10:55 PM
nccracing's Avatar
Its been a while for me but If I remember correctly I took off the hub and thats it. The only trouble I had was putting the new one on. Oh yea , I believe I also had to take off the rear skid. Job only took about 25 min and I had no idea what I was doing.
This was an 03. Dont know about the 04.
Old Nov 29, 2003 | 10:59 PM
Sceiks's Avatar
Did you have to remove the snapring inside the hub? If so do you remember how?
Old Nov 30, 2003 | 02:28 AM
modquad's Avatar
If needed, taking off the wheel hub only involves removing a cotter key, then the hub nut. Take your time, don't get frustrated, then you'll be working against yourself.
Bratman2
Aug 6, 2022 01:42 AM
Bell21
Jul 28, 2015 06:52 AM
Sandman2.0
Jul 21, 2015 09:03 AM
tporath
Jul 11, 2015 12:31 PM
rcappie4
Jul 10, 2015 04:54 PM
