Blown Head Gasket
Old Dec 1, 2003 | 03:31 PM
Blksnshn's Avatar
Default Blown Head Gasket
Well as I said in an earlier thread I had a coolant leak coming out of the over flow but there was no coolant in the oil. Well I went for a short ride today and it got worse. Now there is water in the oil and oil in the water.
So needless to say I am going to be tearing it down to change the head gasket. I ran a cometec HP before, are thier anybetter ones out there?
And I guess it's as good a time as any to go to a stage 2 cam!
Old Dec 1, 2003 | 03:36 PM
UBETRUN's Avatar
How did you torque the last one? When I screwed mine together, Bob Craycraft suggested a few more ft/lbs that the factory spec and to only use the Cometic with the Fire Ring. If I remember correctly, I tightened them all to 24 and then went up in 1 ft/lb increments to 31. I felt the head bolts stretch at 31 ft/lbs and stopped, no problems since.
Old Dec 1, 2003 | 03:40 PM
Blksnshn's Avatar
I torqued it to the manuals specs. I put it together back in march. It just started doing this about a month ago.
Old Dec 1, 2003 | 04:11 PM
shastadog's Avatar
Since your gonna be in to your engine. You might as well check the head and cylinder to make sure the mating surfaces are perfectly flat. I'm not that familiar with Rappy engines but I have seen a lot of aluminum heads warp.
Old Dec 1, 2003 | 04:12 PM
Blksnshn's Avatar
that is a good idea thanks Shasta
Old Dec 1, 2003 | 04:27 PM
PatsRaptor's Avatar
I used the cometic HP head gasket on my stock bore JE 12.1 piston and also went up on the torque specs to 33lbs and left it!
Pat
Old Dec 2, 2003 | 04:25 PM
Blksnshn's Avatar
well I ripped the raptor apart last night and the Head gasket didn't look to bad. Is there anywhere else where water could be getting into the oil?
1ArmBandit
55
Oct 14, 2015 09:03 PM
Sep 23, 2015 06:23 AM
jsmit116
Sep 18, 2015 10:34 PM
Minimod
Sep 10, 2015 09:20 PM
Minimod
Sep 10, 2015 08:03 AM
