400 INJECTOR QUESTION, DONT SEEM RIGHT.
Old Jun 20, 2000 | 04:15 PM
GJ's Avatar
GJ
I have a 2000 Scrambler 400 and am concerned about the injector working properly. I have used 3 tanks of gas so far and the oil level has only dropped about a 1/2". Is this what you guys are seeing? I figured that the oil tank would need refilling after about 4 tanks of gas. At this rate a tank of oil will last all year. I wont stop premixing till I know for sure. Is it working right?? thanks. GJ
Old Jun 20, 2000 | 04:50 PM
94DGblaster's Avatar
that's probably about right.
No Oil injector i ever had used a lot of oil. My Trailblazer never used a lot!
Old Jun 20, 2000 | 04:53 PM
TimC's Avatar
Same here. I bought a Xplorer a couple mnonths ago and have yet to add oil. I bought some "stankless" Polaris gold to put in when needed but haven't needed it yet.
Old Jun 20, 2000 | 05:41 PM
RobCulp's Avatar
My Scrambler hardly uses any too. Don't worry,it's OK. I've found with my snowmobile, I'll use approx. 1 litre of oil to about 20 gallons of gas. You've probably only used about 8 gallons, unless you've run right to reserve every time. That would work out with my theory to about 400ml. But I know the Scrambler doesn't even use that much. I think it's because it's a single cylinder (the snowmobile being a twin requires more oil), so I would guess if you filled it up you would need about 250ml. That I would consider to be completely normal.
Old Jun 20, 2000 | 07:22 PM
TheQuadfather's Avatar
If it hasn't blown up yet, what are you worried about?
Old Jun 20, 2000 | 09:43 PM
GJ's Avatar
GJ
I have been premixing since break-in. Didnt see any reason not to ride even if the injector was broke. It was concerning me though cause it doesnt use any where near the same amount of oil as when you pre mix. I thought it should have been close though. I guess not.
Old Jun 21, 2000 | 03:28 AM
Jaime's Avatar
Pull your plug and look at it what does it look like black and oily or what Also look at the pump sync it is in the owners manual.
Old Jun 21, 2000 | 10:56 AM
walexa's Avatar
Hey Goober, I mean TheQuadMother,
He said he wasn't going to quit premixing until he knew. Do you know what premixing is? Polaris recommends premixing for the first tank to give the engine a double amount of oil to ensure proper lubrication during break-in. He's saying that he's still premixing until he's sure the injector system is operating properly.
franklyme
Oct 21, 2016 07:18 PM
bigred20653
Oct 2, 2015 10:05 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
craacker
Sep 9, 2015 04:32 AM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
