heated gloves
Old Dec 3, 2003 | 06:52 AM
TC450ES's Avatar
Default heated gloves
I'm having a plow put on my foreman and was wondering if anyone has used heated gloves for plowing instead of the heated grips. I thought I read somewhere about gloves that plug into a cigarette lighter socket. I have seen the ones that are battery opperated and was wondering how well they work and if they are worth getting.
Old Dec 3, 2003 | 08:14 AM
trx450's Avatar
I have used Widder Heated Gloves, while roadbike riding in the cold. They were great! DO realize that they draw a bit of current. That, coupled with frequent use of the electric lift, or winch, MAY use more power than the alternator /battery can provide. I am sure Widder has a website for electrical specs. Search: Widder electric clothes.
Old Dec 3, 2003 | 08:26 AM
Camo-man's Avatar
I have never heard of heated gloves ,, only the heated socks...sounds good...
I got a pair of battery operted socks as a christmas gag gift......I put batteries in them one time hunting very cold day
I had to unhook the battery,nice and toasty ,, I save them now for very cold days...
Old Dec 3, 2003 | 07:46 PM
CR724's Avatar
Check out Gerbing.com. All kinds of heated clothes.
Old Dec 3, 2003 | 07:52 PM
thud's Avatar
Heated gloves sound like a great idea and im sure they work, but are the particle? Keep in mind that every time you get on and off the quad you will have to plug/unplug the harness from the quad. Could be a royal PITA if you ask me. Also i've never seen the gloves but how are they wired? Does each glove have a wire thats run through you coat to a single plug? or Does each glove have its own plug? Sounds like more trouble then its worth unless you are talking about EXTREME cold and LONG rides.
Old Dec 4, 2003 | 02:36 AM
TC450ES's Avatar
Guys thanks for the advise. I think I will try the battery operated gloves. I looked at the Gerbing gloves and they were a little expensive. If I do get them I'll be sure to post how they worked out. Then again I may just get the heated grips. If I go that route I think I will get the ones that stick on the bars under the stock grips, I read that the replacement grips are hard and not very comfortable.
Old Dec 4, 2003 | 07:59 AM
trx450's Avatar
Thud-- You take off your gloves most every time you stop, right? Unpluging my Widder Gloves takes less time than that. One plug; 1 second to unplug, or plug in.
Old Dec 4, 2003 | 06:22 PM
thud's Avatar
If im stoppin for an extended amount of time they ya i would take my gloves off.....its the short stops... say to move a tree limb or just to stretch that I could see the gloves being a hassle. Like i said im sure they work fine but for me the inconvenience might not be worth it.
Old Dec 8, 2003 | 09:03 AM
trx450's Avatar
Guess it is all what you are used to. Unless I jump of the bike(or fall off) the gloves, and wiring are not in the way, as the wiring runs down both arms and my back,under my outer jacket, THEN plugs into the gloves.
I also use the snowmobile hand warmers, with chemical warmers. You know, the pouches that look like "Dumbo Ears"on each grip. Don't like THOSE in tight woods situations, though. Whatever works......
lonerider856
Oct 13, 2023 03:45 PM
Jeff Roper
Feb 1, 2022 11:48 AM
Sw00p
Sep 24, 2015 02:50 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
