250 and 400 strokers
Old Dec 3, 2003 | 12:54 PM
dailyrider's Avatar
Default 250 and 400 strokers
Stroking your 250 and your 400's is the only way to go.
Old Dec 3, 2003 | 06:17 PM
Bubba297's Avatar
OK Mr. Badboyz, fill us in on some details. I guess the one thing I want to know is if the powermax setup will outrun the stroker on alky. I would say no but you never know until you ask. Also how's the stroker on the 250 working out?
Old Dec 5, 2003 | 12:05 AM
Whuggs1's Avatar
Ya how did that 250 stroker work out ?
The TrailBoss is running great ! thanks for the carb work Dennis.
Old Dec 5, 2003 | 01:00 AM
Iggysoil's Avatar
Ya were's the web site for the storker cranks[img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 5, 2003 | 09:53 AM
dailyrider's Avatar
The stroker is a great for hill racing and for Drag racing. It is not for the person that wants to dune. The stroker power comes on hard the power max comes on soft,And yes I have tried the other springs in the power valve. And Yes I own a power max. There is 2 things I dislike about the power max 1 is the pipe raddles and makes you look like you are riding a piece of junk. 2 is you can only buy this as a kit you can't build up to it. Most people don't have the money to do this but already have built there bikes up to the hpd race setup. Stroker cost $1600 that is the the crank welding the case and replacing the bearings and porting the cylinder and recuting the head. As for the power between the stroker and the power max on alky the stroker walks right away from it right off the bat. And if you run the power max on akly you WIL brake the piston between The windows in the piston. This is the problem with the 400 motor. The piston to rod angle is to great and it drives the piston into the side of the cylinder wall. I have Fixed that problem and use a longer rod. I have the cranks done to my spec's.
The 250 stroker is a power house in a small motor.
Old Dec 5, 2003 | 06:44 PM
Bubba297's Avatar
I have wondered about the piston/rod angle with that stroke. Great job Dennis. Keep up the good work!
Old Dec 5, 2003 | 07:33 PM
propolaris's Avatar
hey bubba i didnt no you had a water buffalo, what kind of shape is it in.
YZBlaster250
Nov 15, 2001 11:36 AM
mentalmojave
Nov 3, 2001 11:02 PM
gaff
Oct 23, 2001 05:35 AM
BANSHEE4EVER
Dunes and Dune Machines
Dec 20, 2000 08:56 AM
Zorro
Dec 11, 2000 08:56 PM
