Help! replacing starter on old 350 trx
Old Dec 5, 2003 | 02:29 PM
chuckinnc's Avatar
Default Help! replacing starter on old 350 trx
Finally something on my old 1986 350TRX has died. I need to remove the starter, does anyone know if it can be done without removing the left side of the engine. It looks like it should come off with only removing the starter gear cover but it dosent look like there is enough room to back it out of the slot?
Old Dec 5, 2003 | 02:40 PM
Harw's Avatar
There are two starters for that quad. If you have the short shaft it will come out the long shaft most of the time will not.
Old Aug 15, 2004 | 01:47 PM
atvpainter's Avatar
I am having the same issue. Assuming I have a long shaft starter, how di I get it out?? Jeff
Old Aug 17, 2004 | 09:56 PM
atvpainter's Avatar
I still can't get my starter out, has anyone given you suggestions you cold pass along to me?
Old Aug 23, 2004 | 11:55 AM
DirtbagHowie's Avatar
I've got an '88 and was able to remove mine by unscrewing the starter gear side cover, removing the gear and unbolting the 2 mounting bolts to the engine......took me less than 10 minutes.
ghost civic
Jan 15, 2020 07:43 AM
ghost civic
Jul 19, 2015 10:13 AM
Desimation2k8
Jul 17, 2015 12:37 AM
ghost civic
Jul 15, 2015 10:48 PM
mudpig79
Jul 13, 2015 03:31 PM
