clutch kit,worth it?
Old Dec 5, 2003 | 05:33 PM
jimthescramblerguy's Avatar
Default clutch kit,worth it?
i was just thinking about getting a clutch kit for my 500 srambler,do you think it is worth it? will it make a big difference or not very much?
thanks
Old Dec 5, 2003 | 05:46 PM
Scramblerman03's Avatar
A clutch kit makes a huge difference. It's a good idea to get a new pipe when you clutch but if you don't have the cash or whatever reason the kit is still very nice. It will help big time on the acceleration and off the line.
Old Dec 5, 2003 | 09:07 PM
scrambo's Avatar
Get HPD's aggressive clutch kit, you won't regret it.
Old Dec 5, 2003 | 09:50 PM
BigBadScrambler's Avatar
It is well worth it
Old Dec 5, 2003 | 10:15 PM
simster570's Avatar
Is a clutch kit something you can put on yourself or is it something I should take to a dealer?
Old Dec 5, 2003 | 10:23 PM
modquad's Avatar
You can do it yourself, if you take your time. If you've never worked on one before, what you could do is talk to your dealer (always a great idea to get to know your techs) and ask them if you could watch them install the clutch kit on your secondary clutch. I would suggest getting the primary and secondary clutch pullers, and remove the secondary yourself. You can mod the primary yourself, just a simple "put it back together the way it came off". The secondary requires you to be a little careful w/wound up spring tensions.
Old Dec 6, 2003 | 04:10 AM
WileyCoyote's Avatar
If the clutch kits improve performance so much, then why doesn't Polaris put a better clutch kit on their machines? It's not like we're talking about some high dollar, aftermarket performance stuff. Is there a drawback somewhere? Reliability perhaps?
Old Dec 6, 2003 | 04:17 AM
The clutch kit for the scramblers will make the clutch engage around 2200 RPMs. Now that is better if you want faster launches and want to do wheelies. However, for a stock machine, that is too high. Not to mention, clutch kits work better if they are taylored to the pipe. Meaning, that they will keep the engine in the RPM range where the pipe makes its power
Old Dec 6, 2003 | 10:06 AM
ftwflh's Avatar
If you dont want to spend much $$$$ just instal a Polaris white primary spring.
Old Dec 6, 2003 | 11:08 AM
luvit's Avatar
FTWFH,
Can you elaborate more? Meaning, how hard is it to install the springs and at what rpm do the white or other color spings engage at?
buddieboy
Dec 9, 2016 05:50 PM
kodiacrunner
Oct 4, 2015 11:52 AM
tysonbully
Sep 28, 2015 02:30 AM
r1pilot83
Sep 27, 2015 07:38 PM
jbrewster94
Sep 23, 2015 04:16 PM
