400ex Rear Brake Block Off, Need Opinions!
Old Dec 8, 2003 | 02:28 PM
honda400extreme03's Avatar
Default 400ex Rear Brake Block Off, Need Opinions!
I talked to a guy he said i should get a break block off for the back of my 400ex, because the 400ex parking break wears out the brake pads even if you don't use your parking break. Do you reccemend them? Where did you buy yours from? NAC'S? Thanks
Old Dec 8, 2003 | 02:46 PM
Harw's Avatar
No the parking brake will not cause the brake pads to wear out faster.
Old Dec 8, 2003 | 10:04 PM
imported_juggalo's Avatar
yes it does wear out your brake pads faster!! i got my cascade one from rocky mountain atv. its not the prettiest one but looks don't even matter, besides it came with an o-ring and it was only 10 bucks!
Old Dec 8, 2003 | 11:27 PM
sickmojave's Avatar
I got a nice WB from my local honda shop for $12
Old Dec 8, 2003 | 11:42 PM
Quadfather's Avatar
Unless you adjust your parking brake after each ride, it will drastically reduce the life of your brake pads. Take it off, install a parking brake blockoff, buy a new easy pull brake lever and perch, twist and tape the nuetral start wires together, and you're good to go.
Old Dec 9, 2003 | 01:32 AM
NotuRaptor2's Avatar
I prefer the Cascade one that Rocky Mountain sells. It comes with recessed allen bolts and the rubber o-ring seal. With many like the one sold by Nacs, you will have to use sealant and your stock bolts.
/Jon
Reactant
Mar 30, 2022 02:08 AM
XxS0ccerstarxX
Oct 18, 2021 10:03 PM
STLyamwar
Jul 25, 2020 04:44 AM
greg74
Sep 10, 2019 03:03 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
