help wanted
Old Dec 8, 2003 | 08:24 PM
Surfrider53's Avatar
Default help wanted
I have a '01 shee. i recently replaced the engine. i am having trouble getting it started. and with a little help from some carb cleaner it finally starts. it doesnt idle and fires on one piston decently and speratic on the other one. I've cleaned the carbs really well and wonder if there is anyone who has been in a similar situation or may know how to eliminate this problem.
Old Dec 8, 2003 | 09:31 PM
BlackWidow's Avatar
Default help wanted
Sounds like maybe you have a vacuum leak. Check around the carb boots by spraying some WD40 or similar around them. If it picks up and runs better then you know that this is where your problem is. The other suggestion I have is that your choke may not be working right.
You said that you "Replaced" the engine. Where did it come from? Did it run right before you got it or was it a "buy it off the floor" deal??
Last suggestion... are your spark plugs new?? If not, replace them.
Hope this helps and good luck!
Old Dec 8, 2003 | 11:51 PM
Default help wanted
well i siezed the original motor and instead of getting rebuilt i bought one on e-bay. the bike sat for 8 months while i was in iraq and i didnt have a chance to put it all back together until i got back. from what i can see compression is good. it is blowing alot of oil out of the pipes when it is running. i'm running a 32:1 ratio. i try to open up the throttle and it gets sounds really throghty coming out of the airbox, and the revs stay pretty much the same.
Old Dec 10, 2003 | 09:14 PM
BlackWidow's Avatar
Default help wanted
Hmm... it really sounds like spark plugs just off hand. Did you try replacing them?
Old Dec 10, 2003 | 09:41 PM
Default help wanted
yes i sure did. i seem to think it is either the cdi or the ignition coil. i'm leaning more towards the cdi unit.
Old Dec 10, 2003 | 09:45 PM
Ernie660R's Avatar
Default help wanted
Check the flywheel to see if it is loose on the crank. Could have sheared the keyway.
Also check the cranking pressure, should not be more than 5psi difference between the cylinders.
Old Dec 12, 2003 | 02:44 AM
BlackWidow's Avatar
Default help wanted
I don't remember exactly how those things are set up but I do know that both cylinders fire at the same time. In other words, each spark plug is fired twice each revolution of the crankshaft.
I don't know if this makes any difference in your case at all but I figured that I'd mention it.
Nondem
Feb 22, 2020 12:20 PM
nachop
Feb 14, 2018 06:57 PM
Ean
Aug 28, 2015 09:39 AM
NatePerz
Jul 27, 2015 03:27 AM
toonces
Jul 11, 2015 12:01 PM
