V Force carb coolant line removal..
Old Dec 9, 2003 | 07:39 PM
vtwiner's Avatar
Default V Force carb coolant line removal..
I have heard in the past that removing the coolant lines from the carbs might help performance, so before I get myself into trouble removing the coolant lines, I wanted to make sure I was doing this right.
There are 2 rubber coolant lines going into the carbs. If I'm not mistaken, 1 line is in and 1 is out right? So, if I get a straight line adaptor to connect the lines together and clamp them down, I should be ok?
Next, where the rubber lines came off the carbs, these should be capped off right?
Any help would be appreciated...
Old Dec 9, 2003 | 10:45 PM
wildwill's Avatar
You got it!
Just connect the line that goes into the carb onto the coolant filter end instead. Then cap the plastic lines on the carbs.
GregM
Mar 6, 2018 06:53 AM
SDR-II
Sep 29, 2015 01:06 AM
Coryco
Jul 6, 2015 07:30 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
Mikea1978
Jul 4, 2015 12:37 PM
