tire chains or tire studs?
Old Dec 9, 2003 | 10:25 PM
exrider400's Avatar
Default tire chains or tire studs?
which would you recommend? and can you tell me the good and bad about both? thanks
Old Dec 10, 2003 | 10:32 PM
roscoe69's Avatar
studs work great in packed snow, fair on ice. chains work better in most conditions. you will lose some studs, and you will break some chain links. you wont miss the studs but you will stop and remove or fix the chain. if you dont a slaping chain on frozen plastic will present your reward for being slack about it.
Old Dec 11, 2003 | 01:57 AM
NiceFast300ex's Avatar
Powder chain fer sure, icy conditions studs fer sure, I just put 500 studs in a brand new pair of maxxis alltraks and I am kinda bummin about it, I seem to be loosing them, if anyone knows any trick to keeping them in tell me. mabye I didn't get a course enough thread what do other people use???
NO WING NO PRAYER
Old Dec 11, 2003 | 09:10 PM
roscoe69's Avatar
nicefast300ex
in order to keep stud in ,you have to get the type that has a nut on the inside. yep you guessed it drill holes through the tire and put washers and nuts on inside, rubber liner and a smaller then normal tube. sounds like fun doesn't it. its the only way you can keep them in. now doesn't tire chains sound better.
STLyamwar
Jul 25, 2020 04:44 AM
Hondapolaris8596
Jul 28, 2016 03:17 PM
frostphase
Aug 23, 2015 07:36 PM
suzukiquadrunner1987
Aug 9, 2015 08:45 PM
95wolv
Jul 17, 2015 08:13 PM
