TIME FOR THE GREASE GUN?
Old Dec 31, 2003 | 02:15 PM
anth's Avatar
Default TIME FOR THE GREASE GUN?
What all shod i grease on my DS? just the a-arms ?
Old Dec 31, 2003 | 02:40 PM
dsdrew's Avatar
On the swingarm there is a fitting...where it connects to the bike..in the cetre of the shaft top side.
Old Dec 31, 2003 | 06:43 PM
BajaIowa's Avatar
Ditto, and every 100-150 hours I take the rear carrier apart and grease it and the front wheel bearing and the steering stem bearing also.
Justin
Old Dec 31, 2003 | 07:38 PM
anth's Avatar
thx, where do i grease the steering stem at?
Old Jan 1, 2004 | 11:56 AM
BajaIowa's Avatar
At the bottom of the steering stem is a plate that has two bolts holding it down. Inside this plate is a sealed bearing. I just slide the steering stem up and pull out the plate and bearing. I then pull out the seals and grease the bearing, put the seals back in, and good as new. I would not of had to do this except I went to the dunes twice. When replacing the steering stem because it was bent I realized that the sand had gotten inside the plate and was eating away at the seals. Good luck, and I would reccomend to grease the a-arms and swingarm every ride. Grease is cheap and easy compared to replacing stuff.
Justin
slowgsxr97
Mar 18, 2022 03:40 AM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
95wolv
Jul 17, 2015 08:13 PM
ranvette
Jul 4, 2015 06:13 PM
